XPS 13, Spectre X360 or Yoga 720 exclusively for Art?
Discussion in 'What Tablet PC Should I Buy?' started by Sierra Ex, Oct 9, 2017.
  1. Sierra Ex
    Sierra Ex Pen Pal - Newbie
    1. What is your budget?
    Doesn't matter
    New only
    2-in-1 360º Hinge
    13-14"
    Australia
    Any of the above
    Doesn't matter
    Art/drawing/painting
    Windows
    10. What software and tasks do you intend to run?
    Photoshop, SAI, Clip Studio
    no
    no
    Screen Specifics
    1080p at least
    2. Will you be using the tablet outdoors?
    no
    Yes, 1000+ levels of pressure, tech doesn't matter
    Mainly looking at the 3 in the title. It's basically going to be exclusively for art. I know both the Dell and Yoga use Wacom technology and the Spectre uses n-trig, I've never really had a preference as to which one. I'm basically just looking for the best drawing experience on any of these 3 tablets.
    If anyone owns and uses any of the above, how do you like them for drawing? pros, cons etc, any issues with parallax, pressure sensitivity, palm rejection or jitter? Though the main programs i use for the actual drawing part both have smoothing built into the software (SAI and Clip Studio)
    Thanks in Advance
    Sierra
