Xpad Laptop Cooling Pad and Heatshield Review
Discussion in 'News Headlines' started by Gautam, Feb 24, 2007.
  1. Tiffany Boggs
    Tiffany Boggs Editor/Site Admin Senior Member
    832
    The Xpad isn't your typical laptop cooling pad, in fact it has no fans. That is one of the unique features of this cooling pad, besides its lightweight portable design. For those users unfamiliar with the Xpad, it's a portable non-slip laptop pad that cools the laptop while protecting the user from heat.
    Front view of the Xpad cooling pad. (view large image)
    I'll have to say upon first look the Xpad doesn't look like much, but it does allow for better airflow to your notebook. I have never used a USB cooling pad with fans, so I can't say that this one is better, but I can give you the facts on how the Xpad performs. The Xpad is said to keep your laptop up to 30 degrees cooler, I would say more like 15 degrees, but I guess it depends on your computer.
    Features
    The Xpad has three layers of thermal insulation, with insulative air pockets inside , which protect you from the heat. Its ABS composite structure creates a strong lightweight platform that has no flex. In only weighs about one pound, so it is easy to take with you on those trips. It is kind of tricky to get it into your bag though, since it doesn't fold up like some of the other cooling pads that have fans.
    Side view of the Xpad as you can see it isn't very thick. (view large image)
    One thing I liked about the Xpad was the soft bottom layer, which also serves as the third layer of heat insulation. It adds a little cushion to your lap when holding you notebook and it keeps the notebook in place. Having a size of 13"x 10.5" x 0.66" (WxHxD), the Xpad is made to fit laptops with up to 17 inch screens, so you don't have to worry about your notebook being to big.
    Bottom of the Xpad is made of EVA padding, nice and soft. (view large image)
    As I mentioned before the Xpad doesn't use any fans to cool your laptop. Laptops have been engineered so they can cool themselves, although some do this better than others. A laptops cooling system is designed to inhale cool air and exhale hot air through ventilation holes using its own cooling fans. The Xpad provides extra breathing room for your laptop with the 'X' pattern ventilation channel, so it doesn't restrict the natural airflow of your laptop. Therefore the Xpad doesn't interfere with your laptops cooling system.
    My Asus R1 sitting on the Xpad. (view large image)
    Back view of my Tablet sitting on the Xpad, you can see the 'X' ventilation pattern allows for better airflow. (view large image)
    The rubber feet on the bottom of your laptop sit on top of the 'X' pattern rubber pads on the Xpad. The rubber feet provide clearance between the bottom of the laptop and the 'X' pattern rubber pads, so nothing is blocked on the bottom of your computer, which helps keep it cooler.
    The laptops rubber feet and 'X' pattern rubber pads create a high friction rubber-on-rubber contact to provide a non-slip interface. It actually works quite well, in fact my R1 barely moved while on the Xpad. You just have to be careful if you hold your laptop on your lap because it does slide around then, but on a desk it is sturdy as can be.
    The Xpad has no battery draining fans or extra power cords to deal with, which is nice especially when traveling. Overall the Xpad does serve its purpose of keeping your laptop cooler, but it is a little expensive at $24.95. If you buy it in bulk orders though there is a discount. I really don't know why anyone would buy these in bulk, unless it were a business. However one neat thing is that the Xpad's EVA padded bottom is customizable, so if you did order in bulk you could have your company's logo printed on the bottom.
    Pros
      The Xpad is lightweight.
      The 'X' pattern surface holds your laptop in place and allows for better airflow than standard.
      The Xpad is sturdy and holds laptops up to 17"screen size.
      Cons
        The Xpad is expensive.
        The Xpad doesn't fold up, so it doesn't fit in all notebook bags.
        The Xpad isn't available in any other sizes or colors.
        The Xpad is available now for $24.95, but if you buy them in bulk there is a discount, which saves you about half depending on how many you order. For more information or to order check out Xpad's website.
  2. P8RSON
    5,189
    Thanks Tiffany.
    I have never been a fan 'pun not intended' of USB fan assisted cooling trays and as such items such as these I find are much better.
    To further this, the type which I use on all my laptops and tablets is the iLap from Raindesigninc available here.
    I have several of the different sized models, each performing marvelously.
    To see one in action on a T4210 at home see here.
    For the link to the topic that discusses this, see here.
    Regardless, a cracking good review Tiffany.
  3. deepak
    156
    I would argue some of the cons used for the product in this review.
    1) 'it is expensive' - well, actually its cheaper than many products. Cheaper than even those that have a fan in them and (which according to the review and the manufacturer perform not so good). I think the $24.95 price for a working product like this is a very good price.
    2) 'it doesn't come in different sizes and color' - I don't think the color part is anything to mention about. Readers of this post would agree that most electronic items do not come in different colors.
  4. Tiffany Boggs
    832
    I know some users prefer the cooling pads with fans and I have seen many of them for about the same price, just type it in Google and tons come up. To me this seemed expensive I mean it's a piece of ABS plastic and I think that is what many users would say based upon looking at it. First impressions really do go a long way.
    I did say there is a discount for bulk orders, which is nice and the Xpad does perform pretty well overall. (I also did mention in the second paragraph that I am not comparing the Xpad to other USB cooling pads with fans, I am just giving the facts on how the Xpad performed.)
  5. Gautam
    Gautam Moderator
    484
    Interesting review, although I unusually like to see cooling benchmarks, especially because of the unique design (fanless). It's only with actual before and after benchmarks can I know if the pad 'works' or not.
