xp divers for tx 2000
Discussion in 'Hewlett Packard' started by tukiwa, Apr 15, 2008.
  1. khadel
    khadel Pen Pal - Newbie
    hi guys
    i have hp pavlion tx2000 and i downgrad it from vista to xp..but i didn`t find all the drivrs so i need the soud and viga card
    could you plz hepl :eek:
  2. Rudegar
    Rudegar Scribbler - Standard Member
    243
    they are the same as tx1XXX i believe
    so if searching this forum for tx2XXX drivers
    dont give any result you can search for the tx1XXX drivers
  3. ferzun2002
    ferzun2002 Pen Pal - Newbie
    Hi.....looks this
    All drivers for HP TX 1XXX (page in spanish)
    and this
    drivers for TX 1xxx XP
    they are the same drivers for tx1xxxx and tx2xxxx
    bye :)
  4. bya
    bya Pen Pal - Newbie
    How come when I extract the Wlan file from the second link, there's an error message?
    Just found this http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3177437&lang=en
    It's for dv2000 but some of the drivers might work.
    _____________________________________________________________________________
    Edit: Ok, after installing drivers for a long while now I still can't get the touchscreen to work as well as other features on Windos XP. Is there a better way to do this? There has got to be some XP users on the TX2000z before. It's really frustrating.
  5. sfu_lifer
    sfu_lifer Pen Pal - Newbie
    I'm on XP currently. Check that insane long stickied thread in this forum. go to page 4, the rapidshare links are there.
    What sucks though is that the touch screen AND the pen are active at the same time so if you can't write with your palm on the screen. I can't find anything that will auto-deactivate the touch panel when the pen is on.
    Also, do your mics work? Mine doesn't seem to :(
  6. bya
    Thanks for the info, I'm going to have to try it later this week. Too tire now. I doubt my mic works.
  7. khadel
    i tried but this is rar file and need password !!
  8. ferzun2002
    Password: darkgiank.info
  9. bya
    So what's the Megaupload links for if the first two are drivers? I can't read Spanish but I assume it says Megaupload (Require Toolbar).
  10. glibc
    glibc Pen Pal - Newbie
    Hello all,
    I too have the HPTX2114 that I downgraded it to XP PRO.
    How to get the multitouch screen to work in Windows XP
    Please help!
    Thanks.
