Xodo on penabled Android device
Discussion in 'Samsung Galaxy Note and Tab' started by Kumabjorn, Apr 13, 2016.
  1. Kumabjorn
    4,311
    2,382
    For whatever reason it isn't available from Japan. Or did you get it from Samsung's store?
    Sent from my GT-N8010 using Tapatalk 4
  2. Bronsky
    7,709
    4,169
    I think I found it in the Google play store.
  3. Kumabjorn
    4,311
    2,382
    Thanks, I didn't find it in Samsung's Galaxy Store either. I guess they don't offer it to customers with Japanese IP numbers. Probably doesn't support vertical writing or something like that.
  4. siddhartth
    siddhartth Scribbler - Standard Member Senior Member
    830
    300
    There are 2 problems with Samsung's Write on PDF, in my opinion-
    • Xodo is like a proper PDF reader, and by that I mean-
      • It preserves chapters, bookmarks etc like adobe or foxit do.
      • you can interact with the text in the PDF - highlight, strikethrough etc
    • There's a limit to zoom in the Samsung's PDF solution- Write on PDF.
    These are the two limitations of Samsung's offering. It's almost as useful as printed documents because you really can't interact with the original document.
  5. Bronsky
    7,709
    4,169
    I tend to use my GN8 to fill in forms (as in timesheets), to annotate a draft document in PDF or to sign a finished document in PDF. If I need to edit a PDF, I tend to use my S3 tablet and go with Acrobat. But, you make an interesting point. I just don't have the need for those functions. And, you're probably correct about using the GN5 as a reader but it's really too small for comfortable reading. Kindle or other paper white readers are better for that. I tend to use my S3 for reading. The Amazon Kindle App is far better in Android I believe.
    siddhartth likes this.
