Xiaomi Mi Note
Discussion in 'Other Android Tablet Manufacturers' started by Kumabjorn, May 7, 2015.
  1. Kumabjorn
    3,707
    1,751
    This is phablet so perhaps not a tablet if you use a strict definition. However it is humongous for a phone and since they've added Note to the name I assumed it would be similar to a Galaxy Note. However, I can't find anything about a stylus or active digitizer. Anyone here looking close at this product?
  2. manhattan
    manhattan Scribbler - Standard Member
    179
    I had looked into it. There is no digitizer. Chinese are rather liberal with the use of "Note" on the nomenclature of their products. As far as I could tell it seemed like a fine device, for the price. If you're looking for bang-for-buck, without committing much cash into your device, this could be a solid choice. It's not to be compared with flagship devices from major players such as Samsung, HTC, LTG, et al.
    Hope that helps.
    Kumabjorn likes this.
  3. Kumabjorn
    3,707
    1,751
    No digitizer, no deal. Thanks for the info.
