X61T Intel GMA X3100 graphics card upate?
Discussion in 'Lenovo (IBM)' started by swimmerxc, Sep 29, 2007.
  1. pibach
    pibach Scribbler - Standard Member
    528
    exacly the same here.
    My driver: 7.14.10.1244
    date: 30.03.2007
    seemst to be the latest from the auto update.
    Anyone really managed to install the new Intel driver?
  2. swimmerxc
    swimmerxc Pen Pal - Newbie
    19
    just go to that Think Advantage auto update thing to see if your graphics card needs an update instead of manually doing it through my computer
  3. pibach
    528
    nope.
    Lenove hasn't yet released the new one. Until they do and validate the driver, you somehow need to bypass the Vista driver validation which should be possible on the 32-bit Version.
  4. Stansfield
    Stansfield simple polish newbie
    54
    doctorcilantro, please tell us newbies how you did it :)
  5. yggdrasil
    yggdrasil Scribbler - Standard Member
    212
    Download the zip version, not the exe. Then you can unzip all the files and install the driver manually as per doctorcilantro's explanation.
  6. pibach
    528
    Zip or Exe doesn't make a difference. Exe just is a self-extractor. Manual installation only tells me "driver is up to date". Weird how you guys really did it. Any findings in performance increase afterwards? Has the color assignment improved?
  7. ygthb
    ygthb SQA Start-Up Guy
    150
    I did the unzip, then selected the search for drivers option/have disk. This worked fine.
  8. jywang
    jywang Scribbler - Standard Member
    233
    Same games don't work at all with 15.6 so you may want to hold off on installation. (i.e. Lord of the Rings Online does not work)
  9. consolas
    consolas Pen Pal - Newbie
    I had the same problem and the steps below worked for me:
    On the update driver first diaglog, choose "Browse my computer for driver software". On the next one, pick "Let me pick from a list of device drivers on my computer". Then, on the next dialog, click on the "Have Disk ..." and then browse to the inf file in the folder and choose the inf file. You should be good from there. I remember the inf file is in the graphics folder.
  10. pibach
    528
    Thanks consolas for the hint, this finally did it for me. You really have to select "have disk" and point to the .inf file in the graphics folder.
