x41 or tc4400
Discussion in 'What Tablet PC Should I Buy?' started by kersh, Aug 20, 2006.
  1. kersh
    kersh Pen Pal - Newbie
    57
    Who is better tablet??
    How long is the battery of tc4400??
    what i should buy?
    thanks!
  2. daver
    759
    72
    according to reviews i've seen, the X41 gets about a half hour longer battery time (please correct me if i'm wrong) than the TC4200 (similar to the 4400). so i would imagine that the TC4400 doesn't get that much less battery time than does the TC4200.
    however, the TC4400 has a dual core processor for about the same price as the X41. if you are on a tight budget, the tc4400 would give you more bang for your buck.
  3. LeonAnderson
    LeonAnderson Pen Pal - Newbie
    I agree w/ Daver. Tc4400 rocks.
  4. daver
    759
    72
    if memory serves me right, the X41 gets about 6 hours of battery on a single charge, and the TC4200 gets about 5.5hrs - all according to CNET.
    so if you look at the specs:
    X41
    6hrs on 1.6 GHz (or is it 1.8GHz?) Pentium-M processor
    TC4400
    5.5hrs on ~1.8GHz Centrino(?) Dual Core processor
    personally, for the 30 minute difference, i'd go dual core since they're both about the same price.
