X200t: How do i use GPS without WWAN?
Discussion in 'Lenovo (IBM)' started by man_unit, Feb 20, 2009.
  1. Matt3234
    Matt3234 Pen Pal - Newbie
    24
    Hello,
    My X200t came with a GPS receiver. When I start the ThinkVantage GPS software, it tells me that I have to activate WWAN and I have to enter the PIN. However, I have no WWAN plan and do not intend to get one. Can I use GPS without WWAN? Maybe with a different software?
    Thanks,
    Matt
  2. enjoylife
    enjoylife Pen Pal - Newbie
    44
    you can search on lenovo forum.
    you just need to download a program from lenovo
    and turn on the GPS. WWAN is not needed.
  3. Matt3234
    24
    Thanks. I've been to their forum before and read the thread that says that you just have to install the GPS Enabler 2.0.0.1. I've actually got an even newer version (2.11) so this shouldn't be the problem.
    How do I "turn on" the GPS? I haven't found a hardware button. Does it have to be turned on somewhere in the Control Panel or the like? Maybe you refer to the button "Start real-time tracking" in GPS Enabler: When I click that button, I'm prompted to enter the PIN for the WWAN connection (which I don't have). Is there a way to find out whether GPS is switched on even if no satellites can be detected at the moment?
  4. CG-eng
    CG-eng Pen Pal - Newbie
    One possibility to consider is the the "GPS" really uses triangulation of the WWAN signals to determine position. I think that's the way Apple does it. Therefore, no WWAN, no GPS. All the Lenovo documents I have seen says service required...
  5. enjoylife
    44
    Apple is A-GPS.
    I remember I saw a post in lenovo forum that some got the GPS to work without WWAN service.
  6. jonlumpkin
    jonlumpkin Scribbler - Standard Member
    321
    I am still looking for clarification on this as well.
    I have not been able to get on my x200 Tablet (GSM/AT&T), I do not have a WWAN plan.
    The reviews that implied it worked without a plan (e.g. the x300 review) also seemed to have Verizon WWAN cards. These do not use a SIM verification system and may allow GPS without a plan whereas the AT&T may not.
    Any help on a definite conclusion would be appreciated. I have already tried multiple versions of the GPS enabler software and used both Vista and XP without luck.
  7. ratdoc
    ratdoc Pen Pal - Newbie
    Well, I can confirm that the GPS works fine on my X200T with the Ericsson card and GPS Enabler 2.01. The only catch I found was that you have to power up the WWAN card before opening the GPS program. Other than that, everything's been straight-forward.
  8. Matt3234
    24
    And you don't have to enter a PIN or anything? Mine's still not working.
    Can anybody recommend a (freeware) program other than the GPS Enabler to test the GPS functionality?
  9. jonlumpkin
    321
    MS Streets and Tips has a free 60 day trial. You can use this to test GPS functionality. Note, this is a huge (1GB+) download.
  10. man_unit
    man_unit Pen Pal - Newbie
    73
    Everyone,
    You don't have to have service to use the GPS. All you need to do is install the Lenovo program or driver which ever it is. Also, mine uses COM6 (look under 'PORTS' in Device manager)so you will need to install the drivers for that as well.
    At this point you should be able to run the Thinkvantage GPS enabler and after a few minutes you should see the green sat. bars and your coordinates displayed.
    One final thing is to press the fn & f5 key and you will see that the WAN signal is live.
    IMHO it is not worth caring about since you still have to turn it off to access the google maps/earth to plot it. So its no TOMTOM :(
Similar Threads - X200t without WWAN
  1. thatcomicsguy
    788
