X-Keys?
Discussion in 'Acer (Gateway)' started by bignewf, Jun 18, 2008.
  1. bignewf
    bignewf Pen Pal - Newbie
  2. newsposter
    newsposter E295C + a pile of gadgets
    222
  3. bignewf
    Really? I think that if you are going to have an Ergodex DX1 you may as well just hook up an entire keyboard. It's a little big, and all those loose keys, I'd end up losing some for sure.
    Thanks though.
  4. ScubaX
    1,012
    I use Activewords which has a small on screen pad like the TIP. I tap it with my pen, it pops out and I write f11 to hit the f11 key. It is very simple and easy to use and works for any key or combo of keys or other actions such as opening files and starting programs.
