Write protection
Discussion in 'HP Slate' started by ships10, Feb 10, 2011.
  1. PhotoMuis
    PhotoMuis Scribbler - Standard Member
    338
    Assuming you don't have any files bigger than 4 GB (per file), you should be fine.
  2. ships10
    1,525
    180
    Not really...I don't need that kind of security at the moment.
    I am trying to burn some movies to my 16GB card and some data on
    to the 32 GB card. I think dvd movie files are at least 4-7gb.
    Maybe there is a way to encrypt individual files and folders?
  3. dgoodisi
    dgoodisi Scribbler - Standard Member
    160
    I use truecrypt to create encrypted folders on my SD cards.
    I also never put the original DVD files on my SD cards, instead using VidCoder to create a smaller mp4 file.
    I have about 20 movies on my current 32gb SD card, all play just fine on my Slate.
    I leave the original files for playing on the big screen.
    While I use FAT32 for all of my SD cards and thumb drives, I do use NTFS for all of my USB hard drives. By following the recommendations in link from my prior post I make sure that the drive can be accessible from any Windows PC.
  4. ships10
    1,525
    180
    Do you have a link to VidCoder?
  5. dgoodisi
    160
