Woohoo, OneNote for Android now supports handwriting!
Discussion in 'Software' started by spinedoc77, Jul 25, 2014.
  1. Kumabjorn
    4,305
    2,417
    Yay! Downloaded and syncing like there is no tomorrow.
  2. StanrickKubley
    StanrickKubley Pen Pal - Newbie
    Woohoo! I'm thinking of getting a Galaxy Note 4 (over the iPhone 6 Plus) just because of the OneNote inking support. So, to those who've used OneNote on a Galaxy Note, does pressure sensitivity work well? How does the feel of inking compare to that on the desktop or on a Surface?
  3. Deadlywolf
    Deadlywolf Pen Pal - Newbie
    Onenote on Android is making a lot of features for me. It doesn't allow me to change the canvas size of any of my pages.
  4. ron2k_1
    992
    171
    You don't need to. Just keep writing as far as to the right or bottom as you like. The page will size automatically.
  5. Kumabjorn
    4,305
    2,417
    I have the Note 3 and the Note 4 is supposed to have improved pressure sensitivity. It is there on my Note, doesn't mean I'd use it for at work.
    Edit; last words should be art work.
    Sent from my GT-N5110 using Tapatalk 4
  6. alicepattinson
    alicepattinson Scribbler - Standard Member
    168
    Woah it's a great news for some who has difficulty in typing via keyboard. :)
  7. tgv
    tgv Pen Pal - Newbie
    85
    could anyone confirm whether android onenote allows you to save onenote data (notebooks) to an sd card? does it depend on the version of android youre running or not? i have too much onenote data to store on my cellphone's internal memory but I don't need to buy an sd card if it can't be used for this specific purpose.
    Thanks in advance
  8. ron2k_1
    992
    171
    If OneNote saves any data on the phone, nobody knows where our on what format. It does sync to OneDrive automatically or when you're back on Internet.
    Swiped from my Galaxy Note 4 using Tapatalk
    tgv likes this.
  9. Kumabjorn
    4,305
    2,417
    In my case it seems to load pages when I request them, so a continous Connection to the internet seems to be important.
    tgv likes this.
  10. Mesosphere
    5,275
    1,978
    I managed to get everything (5GB notebooks) synced, and at one point I tried to move those the SD card. I can no longer remember why I couldn't accomplish that, but I couldn't. At least with my version of android I think it requires rooting or something (which can't be done with my phone/provider).
    tgv likes this.
