wmc on slate
Discussion in 'HP Slate' started by night_hawke, Jan 23, 2011.
  1. night_hawke
    night_hawke Pen Pal - Newbie
    38
    so i have been playing with my slate, i cant seem to get it to play ripped dvds (yes i own them ripped for convenince). i keep getting video decoder errors, even though they work outside of mce, in vlc and wmp.
    anyone else seeing this?
  2. ridge outfitting
    ridge outfitting Pen Pal - Newbie
    27
    yes I had Same Problem I installed cyber link and the problem went away
  3. TheWerewolf
    TheWerewolf Care for a bite?
    292
    Some DVDs have very odd 'biterror' copyprotection and ripping them normally leaves you with an image that's unplayable. Some commercial DVD rippers can fix this.
    I do the same thing for my father. He has mobility problems, so I ripped all his DVDs to his hard drive on the computer he uses for Media Center (which is connected to his TV). This lets him watch his movies without having to get up and change them.
    Some of them were unrippable and that got me looking for a better solution.
  4. night_hawke
    38
    Not my first rodeo with ripped dvd's they all work on 5 other computers just not the slate. :)
    Why would installing software on slate change it when the other 5 computer dont have that and it works fine on them?
    cyberlink worked!
  5. night_hawke
    38
    I have found that if you use DVDFab it works 100% of the time if it fails its either a damaged disc or you need to update. at least thats my experience.
  6. TWACK
    TWACK HP Addict
    163
    Most likely it is the codec pckg. Shark007 seems to be a top pick these days. Do a back-up, or restore-point and then try. It cured all viewing issues for me on my HP Mini.
  7. krelvinaz
    krelvinaz Systems Analyst
    362
    I don't have a slate yet, but I will check.
    I make copies of all our DVDs when we purchase them and store them on my NAS which is accessible via a media device by the big screen. Don't have to hunt and peck for the DVD we want to watch. I can view it from anywhere in the house as well, but is is not using WMC. Just use Virtual CloneDrive and play it from a network share.
    I use the combination of AnyDVD and Clone2DVD to strip out all the necessary stuff to make the ISO's and Clone2DMDmobile for mobile devices if I bother. Never had codec issues in the past.
    Will give it a check out when I get my Slate though.
  8. thadwald
    thadwald Scribbler - Standard Member
    264
    Handbrake is my favorite tool for ripping DVDs.
  9. dgoodisi
    dgoodisi Scribbler - Standard Member
    160
    DVDFab Decryptor (free version) and Vid Coder (Handbrake frontend) are my tools of choice.
    Resulting files play just fine on the Slate.
Similar Threads - slate
  1. Eltos
    1,779
