Wireless Perfomance Issue While Docked
Discussion in 'HP Slate' started by kartng, Feb 13, 2011.
  1. kartng
    kartng Pen Pal - Newbie
    40
    I spent far too much time this weekend troubleshooting poor file sharing performance between my "main machine" (a 2007 Macbook) and my Slate, and in doing so, I think I've discovered an issue in either my slate or its dock. To make a long story short: I get around 300-400 kilobytes per second when transferring files over my wireless network while the slate is in the Dock, and 600-700 when the slate is in my hands. I've ruled out any sort of software explanation. I saw slightly improved performance in the Dock when I removed the two USB devices I had plugged in, so I suppose it's possible that there is some interference going on there, but the performance still wasn't equal to the out of dock speed. Can anyone reproduce this?
    Given the age and quality of my wireless router, the 600-700 number doesn't surprise me, but the 300-400 number is too slow to stream H.264 720P video reliably, so I guess I'll be watching the better part of my media library with the slate in hand...
  2. TWACK
    TWACK HP Addict
    163
    I bought a USB to Ethernet adapter to connect to my dock. Take a look at the Linksys USB300M. I find it quite handy as some of the places I go do not, or will not, allow WiFi.
    That would cure your prob while in the Dock and since you do not have the problem out of the Dock, no problem.....
    HTH,
    TWACK
  3. Rick
    Rick Sr. Manager, Innovation and Experience
    311
    You can also purchase one from HP at ....
    USB->Ethernet adapter
    Rick
  4. kartng
    40
    Thanks for the suggestions guys. As to date I'm usually more in "work mode" when the Slate is docked, I doubt this will really bother me enough to go wired. I'm just curious as to whether anyone else sees this hit, or if I've just got something in my Dock bleeding interference in exactly the wrong part of the spectrum. I hardly think the Slate has an "antenna-gate" problem - it's just wierd that I lose about 30-40% of my bandwidth when the slate goes in the Dock.
  5. jnjroach
    4,164
    1,626
    How many devices do you have running at 2.4 GHz?
