wireless n on tx2000z?
Discussion in 'Hewlett Packard' started by dpnow.com, May 29, 2008.
  1. p0int
    p0int Pen Pal - Newbie
    How do i use the wireless n on the tx2000z? i have a dlink n-router, but i can only connect with 13.0mbps speed which i think is strange since my cousin's inspiron with a default wireless-g card is connected with 36.0 mbps and i am even closer to my router with full bar than he is in my house. How do i get faster speeds and use my draft-n to its full potential? o_O?
  2. dpnow.com
    dpnow.com Scribbler - Standard Member
    183
    I have a d-link pre-n router and I've had an indicated 200+ megabits per second connection with a tx2050ea. I have read that not all tx2000 models have pre-n as standard, so you may have to double check the specs of your particular model. Another possibility is that your router may not be configured for n-mode, but as you seem to be getting very poor connection speeds anyway, I suspect that there is something technically wrong with your setup.
    Ian
