Wireless HELP!
Discussion in 'Fujitsu' started by quilzas, Aug 23, 2008.
  1. SmokeyJohn102
    SmokeyJohn102 Pen Pal - Newbie
    hi just got my cuzes t series laptop model T3010D. im finding out that the internet is loosing connection then it automatically connects again. it keeps doing this and i dont know whats going on. HELP!
  2. TabbedOut
    1,369
    Are you able to connect other devices to the router without a problem? How far are you from the router (distance and how many walls seperate you)? Is your router optimally placed (high location away from EM radiation)? How many radio transmitters are you using next to your laptop and/or router (cordless phone, bluetooth, pirate radio station, etc)? Are you able to run a cat5 cable to the router and get a consistent internet connection? Have you tried resetting the computer and router?
  3. quilzas
    quilzas Pen Pal - Newbie
    47
    Also, if there's a firmware update that might help the router. Our router was constantingly dropping and reconnecting the internet connection (whether wired or wireless). Firmware update resolved the issue.
