Windows Tablet for Note-taking and Light Drawing
Discussion in 'What Tablet PC Should I Buy?' started by MainelyAnimating, Nov 28, 2017.
  1. MainelyAnimating
    MainelyAnimating Pen Pal - Newbie
    Hey everyone, so I am currently looking for a tablet to allow me to take notes during class in college while having good pressure sensitivity while drawing. The reason for a windows tablet is so that everything is easily transferable between all of my devices.
    I am also planning on trying to remote into my desktop in order to use programs such as Illustrator, Photoshop, and After Effects. This capability is not necessary, but just an added bonus if it is able to work.
    What is your budget?
    $300 USD
    Would you consider purchasing used/refurbished?
    Yes
    Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible?
    Windows tablet or convertible.
    What size Tablet PC would you prefer?
    9+ inches
    Where do you live?
    United States
    Do you have any brand preferences?
    I do not.
    How many hours of battery life do you require?
    4+ hours.
    What will be the primary usage scenario of this tablet?
    Note-taking, drawing, entertainment.
    Do you have an OS preference?
    Windows
    What software and tasks do you intend to run?
    OneNote, Firefox, Atom, Remote Desktop Manager
    Do you intend on playing games?
    Any games are basic windows games like solitaire or minesweeper
    Would you like to stream content through your home theater system?
    Yes.
    Screen Specifics
    Any preferences on screen resolution?
    1280x720 or higher, preferable 16:10 or 3:2 aspect ratio
    Will you be using the tablet outdoors? Do you need to be able to see it through glare from the sun?
    Will not be used outdoors
    Do you require a pen? With or without pressure sensitivity? Do you prefer Wacom EMR, AES, or N-trig?
    Yes, with pressure sensitivity. Dislike EMR.
    Component Specifics
    What size hard drive and memory do you require?
    64 gb for the hard drive is all that's needed, will be using cloud based files. 4 gb of ram is the minimum.
    What sort of inputs do you require, if any?
    SD or MicroSD
    I am currently looking at used Lenovo Thinkpad Tablet 10 devices, along with the ASUS T102HA.
  2. surfaceproartist
    2,930
    1,893
    In order to use Remote Desktop you’ll need to have Windows 10 Pro installed
  3. MainelyAnimating
    surfaceproartist likes this.
