will R1 sd slot read 2-4gb cards?
Discussion in 'Asus' started by cecirdr, Jan 11, 2007.
  1. cecirdr
    cecirdr Scribbler - Standard Member
    I'd like to get a 2gb card as a backup (that I can also use for my camera :) ), but some folks say their card readers don't read them. I know that the 4gb have gone to sdhc format, so my R1 may not read that big a card.
    So...anyone out there know for sure if the R1 will read something like the sandisk 2gb ultra?
    Ceci
  2. Tsukiyomi
    Tsukiyomi Scribbler - Standard Member
    137
    I use a 2 GB SD for backup right now and it seems to work fine. It is a Kingston 2 GB SD card from a few months ago, so its relatively new. I don't know if 4 GB cards will work, I don't have any handy at the moment.
  3. alphaswift
    923
    I'm using a 2GB SD card for readyboost. It works fine.
    Please feel free to send me a 4GB SD so I may evaluate it for you :)
  4. cecirdr
    Hahahaha! :) Thanks for the "offer".
    Thanks for the information both of you. I've ordered the 2gb card since it appears that it'll work with no problem. Since the 4gb cards it's unknown if they'll work...and they're so pricey, I'll wait before considering one of them.
    Ceci
  5. Pezhead
    Pezhead Pen Pal - Newbie
    I've used 2gb SD and a 4gb memory stick duo just fine.
  6. mattj
    mattj Scribbler - Standard Member
    200
    4gb memory stick duo works fine for readyboost??
    I'm going to ebay to upp that bid then :p
