WIFI problem
Discussion in 'Asus (Android)' started by sixthspeed, Apr 10, 2012.
  1. sixthspeed
    sixthspeed Pen Pal - Newbie
    18
    Hi everyone, I'm new here but I've been following the ea800 for a while and I just recently purchased one. So far, It's everything I expected and more, very happy with it.
    I do have a problem however. My school has WIFI that shows up as unsecured and can be connected to by anyone. However, after you connect, you must open the browser to log using your school ID before you can browse. The problem is when I try to use the school WIFI from my eee note, it tries to connect and gives an error saying the connection failed. So I can't get to the browser to enter my credentials. I know many schools and workplaces have this type of wireless network, and was wondering if there was a fix. I'd appreciate any help, thanks.
  2. Micha
    Micha Pen Pal - Newbie
    58
    Well, my university has the same system, and it works fine. Can you provide more information on the error messages and the wifi network you want to join?
  3. GSXRCarlos
    GSXRCarlos Pen Pal - Newbie
    21
    my connection fails if i'm more than 5 meters away from the access point - could it be that?
  4. Muhali
    Muhali Pen Pal - Newbie
    78
    I had the same problem, but have not found an ad hoc solution. Just google 'web authentication' and you will find something. This link may be helpful as well.
    M.
  5. sixthspeed
    18
    I select the SSID from the WIFI list, it tries to connect, then it says "Cannot connect to the selected network. Please check your password and network settings."
    Is the wireless range on this device that weak? It connects to my home wifi fine, but I guess I'm never that far away from the router.
  6. sixthspeed
    18
