Why HP Envy 8 Note is receiving so little attention?
Discussion in 'Hewlett Packard' started by Yongtao, Dec 25, 2015.
  1. zeek
    zeek Scribbler - Standard Member
    222
    Has anyone found a good case/cover? I want one that is very thin material and ideally has a magnet to keep it closed.
    nnthemperor likes this.
  2. nnthemperor
    1,796
    591
    I'm also interested in this and a good too attach the pen to the tablet. Just got the tablet yesterday. Sturdy build, tiny bezel that makes it easy to hold compared to my galaxy note 8, but a very dismal battery. Looks like it's draining every second.
    Sent from my GT-N5110 using Tapatalk
  3. Bishop
    Bishop Scribbler - Standard Member
    350
    328
    I use the ASUS Vivotab Note 8 Versa Sleeve . Good stand. light quick in and out.
  4. zeek
    222
  5. zeek
    222
    FYI. I got this case. I wanted something slimmer but this is working great so far. The tablet attaches with the heavy duty rubber banding on each corner. I was a little concerned that the band on the corner with the power button might depress it but it hasnt been a problem. The Envy stylus fits perfectly in the elastic loop and holds it snuggly but it is easy to remove it.
    http://www.amazon.com/gp/product/B00QSQ5ZZK?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
  6. Bishop
    350
    328
    Doesn't attach. It just slides in as a sleeve. The case flap folds to create the stand surface.
  7. Kumabjorn
    4,309
    2,382
    And don't forget that an extra stylus fits nicely on the top attached to the large size rubber band, so carrying that extra equipment is real easy. Provided tree stylus has a clip, I might add.
  8. zeek
    222
    Its nice but I wanted a case that stays attached to the tablet all the time.
  9. hdfan23
    hdfan23 Pen Pal - Newbie
    98
    Yep you're right it was 200% lowered to 175% and its back, thanks for the tip.
  10. hdfan23
    98
