Why HP Envy 8 Note is receiving so little attention?
Discussion in 'Hewlett Packard' started by Yongtao, Dec 25, 2015.
  1. sitongia
    sitongia Scribbler - Standard Member
    177
    29
    In my case, File History accesses the card more often that I otherwise do, and so reveals the underlying problem. Maybe it is like that for indexing, if the index is stored on C:, then is your access pattern only using the index on C:, more then accessing the card directly?
  2. DevilGear
    DevilGear Pen Pal - Newbie
    ok so it's happening again. had to format the card to get it to work, it's stopped reading it all together, lost everything on there, even my surface book wouldn't read it without formatting. is anyone else having issues with their sd card mounting then unmounting etc? if not then i'm gonna go swap mine out for another unit as it seems mine may have a hardware issue.
    Sitongia The guy at the microsoft store said that was most likely the issue initially but i don't think thats my underlying problem, though it may be the cause of the slower boot times.
  3. DevilGear
    Side note i did grab a Surface Pen loop from the microsoft store and stuck it to the Envy and it Works like a dream I can post pics if anyone likes.
    also anyone have the files for HP InstantNote? i'd like to install it but only way would be to get the files from some one who doesn't have a signature edition from the MS store.
  4. Yongtao
    Yongtao Pen Pal - Newbie
    23
    I can confirm with both my TF cards i don't have the mount/unmount issue you experienced. I experienced once or twice that the card was not recognized at all, but it was easily fixed after i reinstall the TF card. You might be having a hardware (contact) issue with the TF card slot...
    And yes the surface pen loop is a good idea...
  5. hdfan23
    hdfan23 Pen Pal - Newbie
    98
    If anyone is interested buydig has open box Envy 8's for $260 with shipping after CLEAROUT20 coupon code. Search under the Clearance section
  6. bizlazybug
    bizlazybug Pen Pal - Newbie
    Can anyone confirm if the tablet is unlocked and will work on any carrier other than Verizon? I can't seem to find any info about what bands it supports either...
  7. Yongtao
    23
    I have same question, no other sim card I could try yet....
  8. hdfan23
    98
    Well reinstalled Windows 10 from scratch on the Envy 8 and the split screen feature still does not work. Latest drivers, made sure multi-tasking is enabled in settings. Not sure what else to try. Must be some special HP software that enables this. Also a pain to install from scratch, touch did not work after the reinstall, had to plug in micro USB to USB adapter which then connected to a USB hub and external mouse and keyboard, and a USB stick with the drivers. So if you ever have to reinstall, this might be something you'll have to deal with.
  9. bizlazybug
    Try lowering the DPI scaling % in the settings, I noticed when I set it to too high, it thinks the resolution isn't high enough to support the split screen when I tried on my Thinkpad 8
  10. zeek
    zeek Scribbler - Standard Member
    222
    I suspect its limited to Verizon. The Spectre x2 has the same WWAN card and users have had problems getting it to work on other carriers. More info can be found in the Spectre thread.
