Where to buy modular battery for 4210?
Discussion in 'Fujitsu' started by geekocd, Jul 23, 2006.
  1. geekocd
    geekocd Pen Pal - Newbie
    Hi, I just bought the 4210 through newegg (yes! so excited!) and was planning on buying the modular battery through superwarehouse.com but they don't seem to have them in stock right now. I was wondering if y'all had any other suggestions as to the best and cheapest place to buy it?
    Oh, and unrelated second question: is it worth it to buy the fujitsu port replicator over a 3rd party usb docking station? What's the difference?
  2. Barry J. Doyle
    2,153
    You should check with our good friends (authorized Fujitsu reseller and service) at Portable One: http://www.portableone.com . They may be able to get that battery for you. Also, by using the OEM port replicator, you are guaranteed 100% compatibility. If you plan to use it daily, that would be my first choice.
  3. jerrmorn
    jerrmorn Pen Pal - Newbie
    34
    Barry,
    Portableone and Fujitsu had a huge falling out - they don't carry any more Fujitsu products anymore or support them.
  4. P8RSON
    5,189
    Indeed you are quite correct jerrmorn..
    If anyone is interested, read the thread from LeoG.net here.
    It explains what happened between P1 & Fujitsu.
  5. geekocd
    Indeed, noticed the lack of fujitsu products on their site. Anyone else have any recommendations as to where to buy the modular battery for the 4210?
