Where in Control panel do I set landscape for tablet mode on 5010 vista?
Discussion in 'Fujitsu' started by michaelws, Jan 22, 2009.
  1. michaelws
    michaelws Scribbler - Standard Member Senior Member
    783
    114
    Thanks for all the help getting wacom drivers installed on my 5010.
    Where I need some walkthru help is where in the control panel, on vista, on the 5010 do I go to set the computer to remain in landscape orientation when switching to tablet mode?
    No matter what I do, it always goes to portrait (vertical) format when I click it down to tablet mode...I know I can then click the #3 button and get it to change to landscape...but when I go back into computer mode...all my desktop icons are crammed onto the left side of the screen.
    Thanks for any help here.
    Michael
  2. leaftye
    4,127
    Disable automatic rotation. I did that a long time ago, so I forget exactly how I did it.
  3. digs_nz
    digs_nz Scribbler - Standard Member
    104
    If you are asking what I think you are, its in Fujitsu Tablet Controls (icon is little screen with orange on it)
    Click into tablet mode, rotate the screen to the desired orientation (using #3 button) and then click "save current profile". Repeat for each listed "profile" (I dont have docking station so it was just 2 profiles for me)
    Edited to remove some gibberish
  4. michaelws
    783
    114
    I think I figured it out...at least one method...seems to work.
    Control Panel > Fujitsu Tablet Controls
    Under the "Display" tab - Uncheck "Enable Undocked Tablet Profile."
    If there is another way...please let me know.
  5. michaelws
    783
    114
    Digs, thanks...I can see where that method makes sense also. I too do not have a docking station.
    Thanks also Leaftye.
