where can i get a tx1499us motherboard?
Discussion in 'Hewlett Packard' started by thefinalgamer, Mar 14, 2009.
  1. thefinalgamer
    thefinalgamer i miss my tablet
    239
    hi guys, my tx1499us just died on me and hp wants me to pay $450 to fix it:mad: (the case was a little bit cracked) anyone know where i can buy motherboard to replace it myself?
    thanks,
    matt
  2. Kyle Porter
    1,724
    My suggesation would have been ebay, but after checking i had no such luck finding the mobo for your *specific* model. I'm sure any old tx1000 model mobo should work, but wait for someone to verify that fact.
  3. CTSxViper
    CTSxViper Pen Pal - Newbie
    95
    It is in fact the same m/b, so that should help you locate one on Ebay.
  4. thefinalgamer
    239
    thanks, at least there cheaper than what hp was going to charge me
  5. neogen
    neogen Pen Pal - Newbie
    18
    You should not give up.. you should and must get your laptop repaired for free from HP..
    This series of laptop has a serious build problem and HP must acknowledge the same
  6. thefinalgamer
    239
    well my tablet is under warranty but hp is trying to charge me $450 to repair the case because it is cracked a little.
  7. Kyle Porter
    1,724
    Tell them that you don't want the crack fixed. Tell them to ONLY replace the failed part. Keep on hassling them, eventually they give in.
  8. thefinalgamer
    239
    update: hp is sending me a motherboard for free.
  9. Kyle Porter
    1,724
    Good on you! +1 for phone calls.
