What tablet PC for MedSchool
Discussion in 'What Tablet PC Should I Buy?' started by darkaoshi, Nov 19, 2012.
  1. darkaoshi
    darkaoshi Pen Pal - Newbie
    So i need your help guys, my R1F died after lights went off, so here i'm i need to get a new tablet, would love sth portable, been thinking in the S7Slate, but god my budget is realy low. I was thinking about getting the Lenovo Thinkpad tablet wich is N-trig but still have some doubts about it, can you realy rest your palm there??? ok thanks for the answers and advice.
    1. What is your budget?
    500 USD
    Yes
    Tablet (im considering Lenovo Thinkpad Tablet 1838) or Windows Tablet ( I would prefer this one)
    above 10" still doubts about is it better 1280 x 800 in a 12" screen or 1360 x 768 on smaller screen?
    USA, Canda, IDK ebay :S i live in central america so place i can order to my DHL account
    Asus, Samsung, Lenovo, but open to other sugestions
    5 Hrs or mor
    Handwriten notes, patien follow up, reading 500 MB PDF, highlighting them, and handwritten notes on them
    I would love a hackingtosh lol, then again Windows is ok for me, Journal works just fine. Ubuntu its ok as long as i can read and ink my PDF
    MS Office, Note taking app like journal. PDF editing software
    Nop
    yes but it's not that important
    Screen Specifics
    bigger the better, if you can take it outdoors best
    Retina display, or something good enought for reading
    yes
    Wacom please, never used N-Trig
    Component Specifics
    At least 64 GB
    USB ports 3 if possible
    Misc
  2. Bronsky
    6,662
    2,855
    With your budget, if you can find a refurbished or left-over Windows 7, Fujitsu Q552, I would go with that. The dual core Atom is probably the best of the Pre-W8 devices. It is portable, has decent battery power and the Display is great. I am not a big fan of N-Trig, but in Auto mode, you can write with your palm on the display with no problem. If you're going with an Android tablet, the Galaxy note would be my choice in your budget range.
  3. darkaoshi
    thanks i'll check the Q552 and the Galaxy note too
  4. darkaoshi
    What about Samsung Slate series 7 ??? on ebay??
  5. Bronsky
    6,662
    2,855
    If you can find one in your price range, it's a great device. The did have a display lifting issue and battery life is less than optimal but the I5 power is a great feature.
  6. Mhotep
    Mhotep Scribbler - Standard Member
    337
    I'd rec the Series 7 slate with your budget.
    Sent from my SCH-I535 using Tapatalk 2
  7. darkaoshi
    S7S bidding failed lol, Been thinking more in the Galaxy Note 10.1, so question would be, screen size difference matters? can you have sth like windows journal and export to windows? and What about the ATIV smart PC??? is the new atom faster than Exynos Quad core??
