What should I get!? (Tablet Novice)
Discussion in 'What Tablet PC Should I Buy?' started by emc2, Aug 24, 2011.
  1. emc2
    emc2 Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    under $1000
    If its in like-new condition...of course.
    3. Do you prefer a Slate, Convertible or Ultra Mobile PC (UMPC)?
    I don't know what this means, I don't think I want a convertible unless its just an extra feature.
    Compact ~ 10"
    Mainstream ~ 12.1"
    5. Which country do you intent to purchase from?
    USA
    Not really, I am not considering iPads because they have horrible support for what I am looking to do.
    The higher the better, an average school day would be perfect, I can charge while studying.
    Note taking/Drawing mainly! It should be superb at both of these things, I am OK with an average browsing experience but I cannot compromise on the notetaking capabilities and drawing aspects. (Mostly drawing for notes too!)
    Android I guess? I don't know much about tablet OS.
    I don't really know, note taking primarily so maybe Microsoft Office/ Open Office?
    10. Do you intend on playing Games? If so please list.
    No games.
    Screen Specifics
    1. What resolution do you prefer?
    XGA - 1024x768 ~ large and easy to read text and graphic icons but you fit less on the screen.
    SXGA - 1400x1050 ~ Small text and graphic icons which require good vision but the gain is a much larger screen. (no longer available new, must look for used or refurbished machines)
    WXGA - 1280x768 ~ has a wider usable area than XGA, ideal for viewing Spreadsheets and other programs that require desktop space. The mainly used resolution for new tablet PCs since 2008.
    Whatever the best is for mimicking pencil and paper note taking, I am guessing SXGA/WXGA
    2. Do you require the screen to be readable in sunlight?
    It would be a very very big PLUS to have a matte screen that is bright and readable.
    3. Do you prefer your display to be glossy or matte?
    Matte!
    4. Do you require Touch? (without pressure sensitivity) (Which one: resistive or capacitive)
    I don't know which technology would be better for my idea.
    5. Do you require a Pen? (with pressure sensitivity) (Which one: Wacom or N-Trig)
    Wacom makes the art tablets right? So Wacom pen would be OK.
    Component Specifics
    Anything with 32 GB Flash or >
    2. Do you require an Optical (CD/DVD) Drive to be built in?
    ? No.
    No.
    This will be used as a pen and paper replacement for note taking since it is primarily math and physics classes taking notes with a computer is harder. So keep that in the forefront!
    Thanks to anyone who decides to help!
  2. emc2
    No tablet to suit my needs?
  3. pmatulew
    401
    It's hard when you don't know what you don't know. A little research on your own would go a long way. Posts from the last six months are filled with the exact same questions. The booming "tablet" market (and I use that term very loosely), has brought a large number of curious new people into the neighborhood. We just have to take turns being the Walmart greeter.
    You've indicated that you want a stylus and preferably Wacom. That narrows the field by about 95%.
    Try these for a start.
    http://forum.tabletpcreview.com/what-tablet-pc-should-i-buy/43893-tablet-university-business.html
    http://forum.tabletpcreview.com/wha...-has-stylus-pen-functionality-does-exist.html
    http://forum.tabletpcreview.com/wha...-into-buying-considering-tablet-notebook.html
  4. emc2
    I understand if that is the case. Its hard to learn about these tablets without experiencing them hands on, which is what I've been trying to do the past couple of days.
    I am slightly surprised there is no universally agreed on "best note taking tablet."
    Seeing as they are all pretty much crap, one would only have to be GOOD to take the cake.
    I am using the HTC Flyer at the moment, but I am kind of disturbed by the gingerbread phone OS. It seems OK for note taking, only problem is that the screen is too small, way too small.
  5. PhotoMuis
    PhotoMuis Scribbler - Standard Member
    328
    Yeah, that is true, but as there are usually very few places where you can get your hands on a wide variety, you'll have to learn the technical lingo and pros&cons etc. so as to make sense of all the data sheets you'll be browsing...
    Check out this thread, it will answer a lot of the "I don't know"s in your questionnaire.
    http://forum.tabletpcreview.com/wha...ll-you-ever-wanted-know-about-tablet-pcs.html
    For a slate that runs full-blown Windows (so you can run everything from Photoshop to Microsoft Office and - for superb notetaking - Microsoft OneNote, take a look at the Asus EP121. Doesn't have a matte screen though, as far as I know (somebody correct me if I am wrong), but you could probably get a screen protector to take away some of the glare. Convertibles are full laptops where you can turn around the screen and lock it in place to have a "slate-like" device when you need it, quite a few of those are available with matte or outdoor screens (anti-reflective, ultra-bright).
  6. NamelessPlayer
    905
    73
    The HP 2730p with slice battery can be had for $600 or less (used, of course). It's a convertible, but one of the more compact, lighter ones.
    Alternatively, if you want a really large (13.3") screen, look into the Fujitsu T5010.
    You could continue along the Android route and get the Lenovo ThinkPad Tablet (10" screen, N-trig like the HTC Flyer), but then you won't be able to use OneNote, and OneNote is just that good. (I do hope that Android gets something compatible with N-trig pen support, though...said ThinkPad Tablet might make a nice auxiliary to my 2730p.)
