What program do you use for recording lectures and conferences?
Discussion in 'Software' started by everythingblogcast, Sep 1, 2006.
  1. gabrezu
    gabrezu Pen Pal - Newbie
    32
    Hi, I just bought a Toshiba M400 which the integrated microphone featureso I'd like to record the lectures at school. What program do you use for that because the recording program windows has can only record for 60 seconds, so that wont do. By the way, I'm writing this with the pen and it so cool!
  2. Barry J. Doyle
    2,153
  3. P8RSON
    5,189
    If you enjoy what you see in GoBinder, hop on over to MS and there you will also see that part of the Education Pack for TabletPC is 'GoBinderLite'.
    It's limited to 10 minutes of database files but could be ideal.
    If not you can always upgrade to GoBinder Full using the 'education' pricing of $49.95
    http://www.gobinder.com/msgobinderlite
  4. ahamilton55
    ahamilton55 Scribbler - Standard Member
    437
    MS OneNote will record audio and video for you right in your notes. If you're in the US you should have recieved it from Toshiba (I know that the Tecra's at work come with it). If not and you wish to try it MS is give out a 180 day trial of it so you can use it for this semester and if you like it possibly buy it.
    Here's the link to the 180 day trial.
    https://microsoft.order-10.com/onenotedl180day/welcome.aspx?id=osteng180dl
  5. everythingblogcast
    everythingblogcast Scribbler - Standard Member
    176
    Keep an eye out on www.tabletpcreview.com forum and www.studenttabletpc.com will tell you when they have offers on to get the software for free. However you have to do some work to get the serial key for GoBinder 2006 (for example-this happened back in Feb of 2006).
Similar Threads - program recording lectures
  1. Steve S
    14
    1,606
