What Pen are you using? (EA800)
Discussion in 'Asus (Android)' started by thescreensavers, Jul 30, 2011.
  1. thescreensavers
    thescreensavers Pen Pal - Newbie
    51
    I know some people are not using the Pens that came with the EA-800
    So what pen(s) are you guys/Gals using? Do you find it better then the Stock Pen that came with the EA800?
  2. sarah11918
    sarah11918 Pen Pal - Newbie
    98
    I use the Motion Computing L-series pen. The stock pen isn't bad, but a little short.
  3. Ramses800
    Ramses800 Template Trickster
    I went with Jesse B Anderssons recommendation of using a Fujitsu LifeBook pen and truly, it makes a world of difference compared to using the stock pen.
  4. TheTwo
    TheTwo Scribbler - Standard Member
    102
    Hi,
    I'm using the Fujitsu Livebook pen for T5010, too. I'm very pleased with it.
    TheTwo
  5. lyingmachine
    lyingmachine Pen Pal - Newbie
    33
    hi, I have a question.
    as you may know, writing on the edge of the eeenote is not very precise. I would like to ask, if it preforms better when you're using the new pen? If so, i would consider to buy one.
    thanks in advance.
    LM
  6. TheTwo
    102
    Hello,
    At the edges, it is better but not perfect.
    When using the eraser of the pen the eee Note sometimes stuck at the eraser or draws lines even with the eraser. So I use the second button or the menu at the top to switch between pen and eraser.
    TheTwo
  7. Bzz
    Bzz Pen Pal - Newbie
    I use the stock pen, but i put a rubber grip on it, from a spent pilot ballpoint pen.
    works great, but could use an eraser and some buttons :p
  8. monter
    monter Pen Pal - Newbie
    25
    i use my hp touchsmart stock pen - it's a bit longer the the asus one. also noticed that asus stock pen uses only half of preasure. it can be greatly seen if you choose flow pen and draw the line with the full preasure you can. the one drawn with hp's pen is twice wider ;-)
  9. domee
    domee Pen Pal - Newbie
    38
    does a longer pen (e.g. the fujitsu one) still fit in the slot for the stock pen?
  10. TheTwo
    102
    No. You have to put it into the slot in the case.
    TheTwo
Similar Threads - using (EA800)
  1. lblb
    908
