What is zero gravity sensor in Gateway Tablet?
Discussion in 'Acer (Gateway)' started by leaftye, Sep 18, 2007.
  1. bostitch
    bostitch Pen Pal - Newbie
    36
    I notice there is 7200rpm 80GB HD option with zero gravity sensor for Gateway Tablet both C-120X and C-140X small business version. I didn't have that option when I purchase S-7125C (the small business version of C-120X) a couple months ago. Does anyone have any idea what is it?
    My wild guess would be a shock sensor just like the Fujitsu's tablet and Lenovo's tablet. If that is true, I hope it can be added to our existing tablet.
  2. tomtheweirdguy
    tomtheweirdguy Pen Pal - Newbie
    80
    It sounds like a sensor that detects the computer falling and returns the hard drive head to a standby position to prevent damage to the drive. I'm no expet on hdd construction though, so I'm probably calling things by the wrong name. :)
  3. MJCS
    MJCS Pen Pal - Newbie
    80
    A simple google search:
    http://www.patentstorm.us/patents/7199969.html
  4. bostitch
    36
    Thanks!
    The sensor sounds useful to me because it would protect my harddrive (hence my data) when there is sudden acceleration and I imagine it could be used for auto-rotation and other stuff too if someone can write a software taking advantage of this sensor. What's your opinion? Is it useful?
    Also, is it possible to add this sensor to my current S-7125C? Is this part of the hard drive or is it an additional piece of hardware? Does anyone have their Gateway tablet (either C-120X or C-140X) equipped with this sensor? I wonder how good Gateway implement this sensor versus other tablet that has this sensor.
  5. leaftye
    4,129
    These sensors are included in some hard drives. I would recommend swapping out your hard drive before you try anything further.
