what is using up c drive memory?
Discussion in 'Dell' started by recdna, Jun 21, 2014.
  1. recdna
    recdna Pen Pal - Newbie
    96
    I have checked the programs folder and documents folder and pictures folders but all together they don't add up to a gb so what is using up all my drive space? Screenshot (6).jpg
  2. NovaTornado
    NovaTornado Pen Pal - Newbie
  3. recdna
    96
    I'm not looking to optimize anything. I just want a technique to display how much of drive is used for this thing and that thing adding up to the 20 gb that is used up.
    Sent from my Hyperdriven Note 3
  4. Mikerman
    1,289
    123
    The My Dell Drive Space Manager will analyze the drive and tell you what's there. The problem is, I don't quite know how to access it apart from a Notification that the drive is getting full.
    Otherwise, I've used freeware WinDirStat similarly on other systems, and found it informative. WinDirStat - Windows Directory Statistics
  5. Mikerman
    1,289
    123
    Ah, found it!
    My Dell / Checkup / Drive Space Manager.
    It is helpful, although I think WinDirStat more so.
  6. recdna
    96
    I think I saw that. If so it doesn't break down memory by folder, just 4 or 5 vague categories on a line graph. Is that the one?
    Sent from my DROID RAZR HD using Tapatalk 2
  7. FZelle
    787
    197
  8. bubbakush
    bubbakush Pen Pal - Newbie
    23
    tuneup utillitys 2014 has the feature your looking for...if you want an easy way to do wimboot try the google plus wimboot method
  9. recdna
    96
    I was stupid not to buy the 64 gb model.... But it wasn't on sale.
  10. recdna
    96
    So anyway stripping off every program I loaded and putting all my files on sd card I have about 5 gb of free memory. My question is over time will things like windows update or dell update or windows mail files eventually eat up the remaining 5 gb leaving me with a brick that looks like a tablet? I do not wish to remove windows backup from the SSD.
Similar Threads - using drive memory
  1. JoeS
    853
