What is the maximum resolution the T5010 can pump out?
Discussion in 'Fujitsu' started by Tibwolf, Nov 14, 2008.
  1. Tibwolf
    Tibwolf Pen Pal - Newbie
    Is the DVI connection via the dock really limited to 1600x1200 as stated on the Fujitsu site?
    The 4500HD can pump out 2048 x 1536 as per Intel, so wouldnt I technically be able to run a 1920x1200 from the DVI out on the dock?
  2. Grimnir
    758
    I apologize but I don't have a way to confirm this. If you use the Fujitsu driver I'd imagine it would be limited to 1600 x 1200, but if you use the Intel driver like I am you would probably be able to use 1920 x 1200
    Just a guess.
  3. Darak
    Darak <This space for rent PST>
    482
    I'm using the Intel driver instead of Fujitsu's and went and tested this out. I got 1920x1200 working without any adjustment at all (other than having already switched to generic Intel drivers). I did try to do 1080p but it was not natively supported in Windows, but it should be possible by setting a custom resolution (superfuntoomuchworktime)
