webcam issue?
Discussion in 'Hewlett Packard' started by waterfish, Jul 3, 2007.
  1. waterfish
    waterfish Pen Pal - Newbie
    I have clean formatted TX1000, using a custom window vista home premium ( using vlite to strip down sidebar, games etc) installed the drivers, and found that webcam is not detected in msn mesengger... looks fine in device manager.. any hints on how to ''enable'' it if i did actually software disable it in the first place?
  2. Gautam
    Gautam Moderator
    484
    Is it only MSN that has a problem? Were you able to slip in the drivers into Vista with vLite, or did you install them separately?
  3. tariq_niazi
    tariq_niazi Pen Pal - Newbie
    I am having the same problem of webcam detection in msn messenger, yahoo messenger, and eyebeam. Is it a driver issue?
    - TKN
  4. Speed
    Speed Programmer + Tablet Lover
    112
    Personally, I have found the webcam unreliable. I don't have my TX with me to check, but I believe there is a webcam function in QuickPlay. That could help you diagnose if its faulty hardware / faulty driver / faulty software.
    (With my DVB-T Tuner, I could get it to work in QuickPlay but nowhere else for example. Sorted that out by updating the driver.)
  5. tariq_niazi
    I only have had my laptop for less than a week now. I remember in the beginning, the webcam worked with MSN Messenger. Now it will say that the webcam is in use with another program. Is this a driver issue?
    - TKN
  6. topboxman
    topboxman Pen Pal - Newbie
    Take a look at the following link:
    http://forum.notebookreview.com/showthread.php?t=149463
    This may work for tx1000z series if it uses the same web cam as the above link. I told my friend about this link and it totally solved the problem for his HP 14.1" notebook. The worst it can happen is that it won't work and you can re-install the original driver.
    Good luck,
    Peter
