Web Camera Issue on T4310
Discussion in 'Fujitsu' started by Loua, Oct 26, 2011.
  1. Loua
    Loua Pen Pal - Newbie
    I have used my Lifebook T4310 for 15 months and it is now indispensable in my work as a teacher. I began to use One Note and the web camera to record students giving speeches. It worked well until this week when I changed the screen orientation using the buttons while also recording video.
    Now the web camera is recording upside down in all programs in which it is used- Skype, you cam, messenger.
    I can not find any way to reset it. I have used the restore option to see if that helped but no luck.
    Are there other options I could try?
    Thank you
    Loua
  2. 123Fels
    123Fels Pen Pal - Newbie
    71
    Strange...have you tried to uninstall the FJ Camera in the device Manager and then reinstall (use original Fujitsu drivers from Fujitsu website)?
  3. Loua
    I tried the reinstall driver but the web cam still records up side dowm..:confused:
    Would appear everything is functioning .. except - its upside down.
    Next try Fujitsu
