Way to view One Note pages in Separate Window?
Discussion in 'OneNote, Evernote and Organizers' started by Grinner, Nov 1, 2007.
  1. Grinner
    Grinner Pen Pal - Newbie
    84
    Hi, I wanted to know if anyone knows if it is possible to view One Note pages in a separate Window, so I can display some notes on my secondary monitor while working on a different page at the same time ?
    I often need to use algorithms to solve problems and not constantly having to switch pages would save lots of time.
    Thanks!
  2. ahamilton55
    ahamilton55 Scribbler - Standard Member
    437
    If you go to Window --> New Window you create another window for OneNote. Just drag that over to the other screen and they both edit the same files.
  3. P8RSON
    5,189
    ..... and Andrew beats me to it. :)
  4. Grinner
    84
    Oh wow. That was waaaay to obvious for me... I swear I checked everything and then it hides in plain sight. :)
    Thanks a lot!
