Warranty question
Discussion in 'Fujitsu' started by sacley, Jun 2, 2013.
  1. sacley
    sacley Pen Pal - Newbie
    Hi everyone,
    I am going to order a T902 tomorrow, I was wondering if upgrading the hard disk or RAM by myself voids the warranty?
    This might sound like a silly question but I'm new to this, any comments are:confused: appreciated!
  2. Steve S
    8,173
    3,675
    <<...I was wondering if upgrading the hard disk or RAM by myself voids the warranty?..>>
    sac: The RAM, No. The HD, probably yes. (This is due, in part, to the fact that your Windows OS installation is linked to your HD, not to your tablet.)
    HOWEVER, simply keep your original HD, and reinstall it if you ever need to return your T902 for service...
  3. Zero
    493
    What about adding an m-SATA drive?
  4. utopian201
    199
    14
    if you return your device for warranty repairs, you can remove your hard drive; I removed mine before sending it away. They just use a service hard drive to carry out repairs.
  5. monicajae
    monicajae Pen Pal - Newbie
    shouldn't, but check with the issuer. these are modifications that are superficially doable. IOW, you don't have to take the machine apart to install/remove them. plus, most manufacturers offer instructions on how to replace or upgrade just what you are talking about which makes the act "legal"
Similar Threads - Warranty question
  1. OriginalDan
    1,693
