Wacom Pen - Any with two buttons and an eraser?
Discussion in 'Acer (Gateway)' started by ajurna, Mar 1, 2008.
  1. ajurna
    ajurna Pen Pal - Newbie
    I await my 141xl...
    Just wondering if there are any wacom powered pens out there that have two side buttons and an eraser on them? Might as well get all of the options if I can.
  2. tomtheweirdguy
    tomtheweirdguy Pen Pal - Newbie
    80
    I don't know about any that can be purchased retail, but I do know my friend's Fujitsu convertible notebook came with a pen that had an eraser and two side buttons. If you can't find one online (check wacom's website as well as www.newegg.com) that meets your needs, get in touch with Fujitsu and order one or two as "replacements". Keep in mind that the pen slot in your Gateway will not accomodate any pen other than the one specifically designed for it.
    In case a Gateway rep happens to read this, Gateway would make killer money if they would sell a pen for tablet PCs that has these features and fits in the slot!
  3. Nominal
    Nominal Engineering Student
    199
    True! I would pay a premium for a better pen that fit in the pen garage.
  4. nikecar
    1,524
    i wouldn't. :D
  5. leaftye
    4,127
    As the others have stated, there isn't one that'll fit properly in the pen silo, but there is a Wacom pen with two side buttons and an eraser:
    UP811E
    As far as I can tell, it's only available directly from Wacom.
  6. newsposter
    newsposter E295C + a pile of gadgets
    222
    Has anyone verified that this two button/eraser pen works with current generation gateway (Wacom) tablets (141xx, E295, etc, etc)??
    thanks!
  7. Shogmaster
    4,192
    1,443
    I will verify it. I saw the exact pen used with Penabled Tablet PCs before. But for $50, I'd rather get the Cintiq 15X none-grip pen. Same price, thicker casing, and better feeling tip action.
    http://direct.wacom.com/stores/5/Pen_for_Cintiq_15X_not_Grip_s_P1176C62.cfm
  8. newsposter
    222
    So the Cintiq pen has two butons and an eraser?
