Wacom MobileStudio Pro
Discussion in 'Artists' started by BobBee, Oct 4, 2016.
  1. eatboxman
    eatboxman Pen Pal - Newbie
    Hey guys. I have the 16". Was wondering if anyone is worried about the heating? Like, in a year over time, do you think the overheating could damage the insides? I think out of all the ways the MobileStudio Pro would die, it would be from overheating the most.
  2. daaaaaaac
    daaaaaaac Pen Pal - Newbie
    The colors on my device (mobilestudiopro 13 512) are very saturated in comparison to my macbook pro 15 and also the ipad pro. Is there any way to change it..? Thanks!
  3. Brashen
    Brashen Pen Pal - Newbie
    19
    Go into tablet properties and you should find an option there to change it
    daaaaaaac likes this.
  4. stoneseeker
    3,341
    783
    In general this shouldn't be a concern for your main hardware (CPU/GPU, RAM etc). Intel CPU's and other major components are made to withstand a LOT of heat, and all have systems in place to shut themselves off before they will ever get damaged. Heat can effect performance in the moment if thermals are poorly handled, and one part that CAN take a hit from heat is usually the battery... but the main system is very unlikely to be permanently effected by heat. A far bigger concern to me with Wacom hardware is their track record of picking cheap parts for assembly like the infamous AC pin in the power socket of the CC, and other small things that break down with common use scenarios.
  5. artistebot
    219
    235
    Agreed.
    The Wacom track record for is spotty. Time will tell if the MSP is less prone to hardware failure.
    I still love using my CCH. I have access to two of them and one has the cable/charging port starting to fail. I don't know how to fix it as it appears nobody has taken one apart.
  6. Azzart
    1,491
    991
    It depends on the graphic card but generally you need to right click on the desktopand select graphic/display properties. Intel for instance has a panel where you can change a serie of things like gamma, brightness and contrast.
  7. eatboxman
    Thanks for the info! Yeah, sure do hope they did it right this time. So far so good! Will we survive the beta test? Hopefully.
  8. VagrantTrail
    VagrantTrail Swarming Colors Metastasize
    93
    61
    A summary of the MSP 13 from the guy that found a carrying case:
  9. VagrantTrail
    93
    61
  10. KennyJenkins
    KennyJenkins Pen Pal - Newbie
    Ive been really happy with this bag
    http://www.ebags.com/landingpages/tlsprofessional
    it fits the 16" and all the accessories quite safe on commutes, and its # of areas and pockets are expansive
    new question: where is the 3D software thats supposed to come with this? I got documetnation for the year of PSCC but didnt see any mention of the 3D scanning software. Ive been playing with the SDK from intel but would like to exploit the stuff thats included.
    K
