Wacom MobileStudio Pro
Discussion in 'Artists' started by BobBee, Oct 4, 2016.
  1. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    989
    557
  2. Azzart
    2,261
    1,570
    ATIVQ likes this.
  3. kruzilla
    kruzilla Scribbler - Standard Member
    227
    I have it and it works fairly well for the MSP 13" but it can be fairly annoying to adjust. It's pretty good if you're like me and work on your couch.
    FWIW, I've ended up just using my lapdesk with my Thule Gauntlet case as a makeshift "stand". Unfortunately, I believe it would be too small for the 16".
  4. surfaceproartist
    2,983
    1,910
    Azzart likes this.
  5. Stalio
    Stalio Illustrator
    21
    I have it, and I mean exactly that model and brand, and I am using it with the MPS 16.
    Honeslty I find it very efficent and versatile.
    Well, if you want to stay just on the desk, maybe you can find something better, but if you really want to switch between different positions, on the couch, on the bed and so on, it works great.
    Obviously, with longer positions on the couch the stability will decreases, with shorter positions it becames more stable, nothing so strange anyway, I think you can expect this if you think about it.
  6. Brian123
    134
    95
  7. VagrantTrail
    VagrantTrail Swarming Colors Metastasize
    93
    61
  8. daaaaaaac
    daaaaaaac Pen Pal - Newbie
    When I tap the screen and hold for some seconds it performs as a right click. Anybody know how can I disable this? Maybe in windows is useful but that's very annoying in photoshop using the pencil.. When I'm doing some dots or small details it appears always the brush settings.. I love this device but windows is really killing me..thanks!
  9. surfaceproartist
    2,983
    1,910
    Go to Control Panel > All Control Panel items > Pen and Touch.
    Under Pen actions, highlight Press and hold and then tap Settings. On the next screen you can disable the behavior but I recommend that you try to lengthen the time required for the hold to register.
    hinze likes this.
  10. daaaaaaac
    Great! It worked, Many thanks :)
    I have the 16model i7 512. It works great but as I am planing to travel alot while working i'm thinking to switch to the 13model I7 512 for traveling light.. My big concern is if this one will work fast as the 16model? I only use photoshop for drawing and painting. Will I notice any big difference for working with lower graphics in photoshop? thanks again!
