Wacom Feel-it Drivers for TabletpC : no more middle click ?
Discussion in 'Software' started by xxxxx, May 8, 2019.
  1. xxxxx
    xxxxx Pen Pal - Newbie
    24
    hey all,
    I just bought a refurbished HP x2 1013 g3 (wacom AES 2.0 MPP 1.51).
    With the recent wacom drivers (> 7.5.1-xx), I can't find any option to map the middle click on the side buttons of my stylus.
    On my Yoga 720 15IIKB with wacom feel driver 7.3.4-38, the option is still here.
    If I use the HP Rechargeable Pen on the Lenovo, it's recognized and the side buttons work as middle click and right cick. Unfortunateley I can't get 7.3.4_38 to install on the HP.
    It seems Wacom removed the option to map middle click sometime between 7.3.4-52 and 7.5.1-29.
    7.3.4-52 revA gives me right and middle click option, but I loose tilt sensitivity and there's an issue with the right/middle clicks sending 'scroll down' command when they are pressed, so I'm currently trying to find older drivers (>7.3.4-52 and <7.5.1-XX) to get the middle click functionnality on the HP x2 1013g3 (ideally with tilt and no issues).
    anyone had old drivers somewhere ?
    alternatively I'll have to find a way to remap the barrel buttons. TabletPro is not working reliably on HPs.
    any help is welcome. Thanks
    edit : just found this wacom component drivers page but no drivers fits my requirements :
    http://www.wacomeng.com/component/wacom-components.php?auth=3944830928
    edit 2 : Nevermind, the side keys can be remapped with autohotkey (somehow it didn't work with HP's customized drivers, but it works with wacom 7.6.1-22) so everything is working fine now.
    boombyte and WillAdams like this.
  2. boombyte
    boombyte Pen Pal - Newbie
    Hello.
    I asked that in NotebookReview forum.
    But I have T902 and some others wacom-tablets.
    Can you explain this---
    1---what is autohotkey? Is it HP utility or Lenovo?
    2---Where I can get wacom 7.6.1-22 drivers? (For some strange reason I can't open that wacom-link)
