Wacom Enhanced Driver Penable Device
Discussion in 'EP121 Slate' started by CF77, Apr 12, 2011.
  1. buda81
    buda81 Pen Pal - Newbie
    45
  2. porongo
    porongo Pen Pal - Newbie
    43
    thanks to CF77. I just uploaded hehehe
    Did you try the 707-4? they worked?
    This artdock works good with win8?
  3. alexands
    alexands Pen Pal - Newbie
    Thanks Porongo. Unfortunately, I can't seem to get pressure in Photoshop with Win 8 to work even with these drivers. The brushes pallet continues to show locked symbols.
  4. buda81
    45
    the artdock works great, just make sure you use the e121 script instead of the S7S
  5. porongo
    43
    you are using an Asus EP121 machine? It should work... I have photoshop here and works perfectly (disabling EETI of course)
    Make sure you uninstall any ISD before installing 707-4. Run Ccleaner, install 707-7 (reboot), install 706-6 (reboot), and install 707-4 again (reboot).
    That's what I did and I have pressure with all software.
    what about you Buda? The drivers worked? Do you have pressure?
  6. Kompleet
    Kompleet Pen Pal - Newbie
    Hi, and thanks for the drivers Cf77 !
    But, this thread is really hard to follow and feels like playing a "create your own adventure" book with stuff like "go to post 303" and then, "go to post 292" roll dices, and if you get a double six, your wacom driver will work !
    Ok, seriously, would it be possible to write a full recap by editing the first post with step by steps instructions ?
    I did a clean install recently, and I installed 702, 706 and then 707, as you told us, but like one of the users here, everything is messed up in art rage and sketchbook pro, and I can't find the origin of the problem...
    So I revert back to the official 702 driver from asus. So, what are the advantages of upgrading to 707 ?
  7. porongo
    43
    I agree with you, Kompleet. Its hard to keep following this thread, since we've got a mix of Asus, Samsung, Tm2 users and different operating system and scenarios too.
    Maybe a sticky thread for win8 Wacom drivers would help a little and prevent mixed info.
    But reading CF77 posts and users experiences, will do the job for those who can stop the day and do a little research.
    Anyway, it would be great if we get a fresh new Wacom sticky thread.
    Regarding your question: If you are not having problems with 702 theres no need to install 707.
  8. buda81
    45
    nope, no pressure on CS5. I just switch to win 7 for my pressure needs for CS5. hoping for better results on the next update.
  9. porongo
    43
    that's odd... I have pressure in everything with Win 8 here.
  10. porongo
    43
    Here's one snapshot from my desktop with PS working pressure on Win8
