Wacom Driver for C-140x Vista (32bit) ok?
Discussion in 'Acer (Gateway)' started by Flook, Sep 8, 2008.
  1. MadRavenOo
    MadRavenOo Pen Pal - Newbie
    42
    I was wondering if I 'need' to update the C-140x with the wacom driver or not?
    (or does it already come with the latest drivers from wacom? anyone notice the difference?)
    And where is the driver?
    On the site it brings up a file to download , but it only mentions for XP
    (are these the same? just doesn't say vista?)
    I'm just wondering as I thought I remembered someone having more issues after installing the drivers, so I just want to be sure of which drivers it was.
    thx in advanced
  2. waplespunk
    waplespunk Scribbler - Standard Member
    169
    There is a bug with the Wacom drivers and Photoshop. You first need to download the 5.05 drivers here.
    Then, follow the steps here.
    There is a problem where the pen won't line up with the cursor in some graphics apps. I spent a lot of time on the phone with Wacom and they provided the fix above.
    About why you want the Wacom driver... well, it adds preasure sensitivity. If you want to draw, you'll want this.
  3. tomtheweirdguy
    tomtheweirdguy Pen Pal - Newbie
    80
    That links to the Graphire drivers. Are you sure they can be used with the Penabled tablet? They have a different page for the TabletPCs. Did Wacom suggest using that driver?
  4. waplespunk
    169
    Yes, Wacom told me, over the phone, to use that one as it's more updated than the one on the tablet pc page (5.03).
  5. Chocobo
    417
    Alright, I did the fix. Will awful things happen to my computer beause of this, or does it work?
  6. Fly High
    Fly High Time to name this baby
    55
    A few days ago Wacom just released version 5.05-7.
    I have not yet updated Wacom drivers. Should I get version 5.05-7? Or version 5.05-5?
  7. ironfinger
    ironfinger Pen Pal - Newbie
    24
    i dunno, but I did install the latest. It did the fix photoshop. However, ArtRage and Alias Sketchbook lost sensitivity. I'm not sure if that happens with .-5? Anyone know?
  8. nikecar
    1,524
    did you do the registry edit too?
    I am going to have to install the new version soon. i've had it a few times where after powerup, the Wacom driver crashes and I cannot use the pen. i have to reboot and it works. This has occured AFTER the regedit for the calibration issue.
  9. ironfinger
    24
    yeah, I did the regedit to get photoshop to work. But when I do that, I loose sensitivity in Alias sketchbook and Art Rage.
    Also, with the regedit, photoshop looses calibration when you rotate the screen to vertical, or 180% mode. I think we need a better fix for pshop than the regedit deal.
  10. MadRavenOo
    42
    I agree, but till wacom releases an 'official' tablet pc driver, I think we just have to deal with it.
    It's annoying not being able to recalibrate and the not being able to use the vertical screen orientations.
    But at least the sensitivity works and the pen is calibrated well enough to work with (still better to draw on tablet pc screen than a separate drawing tablet, IMO)
