1. We will be upgrading to the latest version of XenForo today beginning at 4:30 PM ET. We expect about 1 hour of downtime during this process. We'll remove this notice when the work is complete - sorry for any inconvenience!
    Dismiss Notice
Wacom digitizer pen gets stuck in the silo with E-155C or C-120X.
Discussion in 'Acer (Gateway)' started by ubiquityman, Mar 7, 2008.
  1. ubiquityman
    ubiquityman Pen Pal - Newbie
    Does anyone else have the problem with the pen getting stuck in the silo?
    The mechanism is such that if I push the pen straight in, or push it in and to the left, the slot in the pen which is supposed to contact the spring tab mechanism slips past the little tab inside the silo and the pen gets stuck. If I push the pen in and to the right which pushes it against the spring loaded tab, then no problems. Seems like there is too much play between the little spring loaded tab that's inside the silo and the pen itself.
  2. jgjackson
    jgjackson Scribbler - Standard Member
    485
    yes. It is a universal problem. I took a small rubber band and pushed it down to the bottom of the silo so the pen doesn't go all the way in.
