Wacom Cintiq Companion 2 Discussion Thread
Discussion in 'Artists' started by whazzup, Jan 6, 2015.
  1. DaniJoy
    DaniJoy www.danijoy.com
    565
    257
    mine did the same thing this morning upon wake up from sleep. i have not used the connect feature. i was painting last night in photoshop, and put it to sleep. when i turned it on, it would flash between the desktop and the opening password screen. the only way i could get it to stop, was by a full restart. using the power button only put it to sleep and it would have the same issue upon wake up.
    Maybe its a bug with the new Graphics drivers that just came out a couple days ago?
  2. Brian123
    136
    99
    Thank you for sharing your experience. Good to know it happened outside the use of Cintiq mode and may just be from the recent windows/graphics driver update.
    For now, I guess we should all save work each time putting this into sleep or Cintiq mode to so we don't lose anything with forced restarts.
  3. PGross
    PGross Scribbler - Standard Member
    112
    39
    So my CC2 is calming down, fan-wise. I dumped Windows 10 for now because it's buggy yet, and went back to 8.1. The only major problem is that the touch seems overly sensitive and palm rejection is working poorly. I always wear a smudgeguard glove with my cintiqs, and that has always eliminated errant touch issues. But I keep getting random touches from palm and knuckle through the glove. I even double gloved and still got the random touches. Anyone else noticing touch sensitivity?
  4. Plognark
    176
    25
    Actually, the same thing is happening on my CC1 after the latest driver updates. I also use a glove to keep skin oil and sweat from smudging up the screen. Used to be able to brush dust off of it without any input, but now it does detect the edge of my palm as if it were a single finger stroke through the glove. I don't think this is specific to the CC2, it's probably touch screen driver related.
  5. Dex1
    Dex1 Pen Pal - Newbie
    35
    It may be a good idea to start tweeting and messaging Windows and Wacom support about their driver issues if this is the problem.
  6. PGross
    112
    39
    I connected it in Cintiq mode to my iMac and it has the same touch issue.
  7. ramosdesign75
    ramosdesign75 Pen Pal - Newbie
    I am getting the same results here on CC1 512 as well. I assume the gloves are no longer usable due to the now hyper sensitive driver. Possible solution: Anyone know of a hotkey script that can at least keep a section (opposite side of your drawimg hand) of the screen available to do touch gestures or make more buttons to remedy the unwanted marks on the art onscreen? Currently I am just working with the touch turned off completely.
  8. gian-reto
    gian-reto Pen Pal - Newbie
    If you just want to see the sensory data:
    http://en.wikipedia.org/wiki/GPU-Z
    http://en.wikipedia.org/wiki/CPU-Z
    If you want to tweak, you need other tools (OC Tools basically):
    http://en.wikipedia.org/wiki/Overclocking#Graphics_cards
    http://www.almico.com/speedfan.php
    Maybe the speedFan Tool is what you are looking for?
  9. Axiom
    Axiom Pen Pal - Newbie
    Yeah same thing here. I just setup one of my wacom pop up shorcut buttons (can't remember name for the life of me atm) things to turn off touch when I work. I honestly don't use touch while arting.
  10. carry86
    carry86 Pen Pal - Newbie
    hi all. just an update. i definitely LOVE my CC2 512. i work on the go in maya and it works like a charm. so far i get close to 3hours on the battery and i am on high performance. :)
    i don't use touch so i didn't experience your issues but hopefully the driver will be updated soon and correct this..
    Happy ! :D
    Dex1 likes this.
