Wacom Cintiq 16 Pro (PWM)
Discussion in 'Artists' started by axel9546, Dec 2, 2019.
  1. axel9546
    axel9546 Pen Pal - Newbie
    Hi guys!
    I wonder if any of you could test the "WACOM CINTIQ 16 PRO" to check if it use PWM to regulate brighntess.
    This is a very bad thing called screen flickering, that could increase headhace eyestrain on sensitive user.
    If any of you also could share their specs with HWINFO on the "Monitor section" to see what DisplayPanel, the wacom cintiq use!
    Thanks!
    You can test PWM with a oscilloscope, or with simpler things
  2. axel9546
    Okay so i have the chance to have one user sending me this!
    I cant find what model of panel it use. Anyone could help? 78866406_707093663027562_6828167946670440448_n.jpg
  3. kurt corbin
    kurt corbin Scribbler - Standard Member
    204
    70
