Wacom ALT+RIGHT CLICK Windows Ink BUG fix...
Discussion in 'The Tablet PC Life' started by artistebot, Apr 4, 2018.
  1. artistebot
    435
    416
    This may be old news...
    When setting up my Zbook X2 w Photoshop CC I found that I could not get the brush resize function to work. Coming from Mac this issue did not affect me, so dang...!
    Someone posted a solution on Reddit , that seems to fix the issue.
    https://www.reddit.com/r/wacom/comments/87syy9/wacom_users_if_you_want_to_see_the_altright_click/
    Instructions:
    1. Create a file that contains instructions to revert to the WinTab functionality.
    2. Create a text file in a text editor such as Notepad.
    Type in the following lines:
    Use WinTab
    UseSystemStylus 0
    1. Save the file as a plain text file named PSUserConfig.txt
    2. Put (copy) the file into the Photoshop settings folder: C:\Users[User Name]\AppData\Roaming\Adobe\Adobe Photoshop CC 2015\Adobe Photoshop CC 2015 Settings\
    3. Restart Photoshop and check the pen pressure and overall performance.
    So maybe not news, but it was to me!
  2. Azzart
    2,261
    1,571
    Yep, it's a common known way to force Wintab in Photoshop on Windows. ;)
    artistebot likes this.
  3. stoneseeker
    3,607
    1,062
    wow didnt know that either!
