W500 - Erratic Screen Flashing
Discussion in 'Acer (Gateway)' started by bowruss, Jun 1, 2011.
  1. AllenPapapetrou
    AllenPapapetrou Scribbler - Standard Member
    Mar 5, 2011
    104
    Hawaii
    Aloha blackdemon,
    The YT video is from Acer support and was updated on 1 July. If I had the problem I would apply their solution. Very straight forward and well done video. I'm impressed...
    Allen
  2. blackdemon
    blackdemon Pen Pal - Newbie
    Jul 2, 2011
    Aloha Allen ....
    I've tried the solution proposed on the video .... it work!!
    the defect is gone immediatly .
  3. excalibur1814
    Jan 13, 2011
    1,898
    92
    Last night sitting there while charging two USB batteries the usually screen flashing started as the show desktop button was activated. Yep... I have the latest firmware update so there you go. How did I get it to stop? I tried tapping the right lower side but that didn't work so I put my hand around the area (rear, side and front) which made the flashing stop.
    Muh.
  4. Flamingfarts
    Flamingfarts W500 owner
    Jun 17, 2011
    53
    I consider the possibility that static electricity may be a cause. All the ingredients of concern are there : the metal chassis and backplate, a capacitive screen, the magnets and finally the screen shield appears to be a kind of vinyl .....
    By putting your hand behind without applying any pressure, you have acted like a ground and removed any static electricity on the device and stopped the flickering.
    i know it's a shoot in the dark but who knows ?
  5. excalibur1814
    Jan 13, 2011
    1,898
    92
    Hey... works for me :)
    Still really liking this device. (Could do with a couple more hours on the battery life though)
  6. ACIWD
    ACIWD Pen Pal - Newbie
    Jun 5, 2011
    There is a new update for the touch panel at Acer Downloads in the BIOS section.
    Touch Panel Firmware Updater Acer_1005.2003 Release date:2011.07.19
    Also a new update for 3G.
  7. excalibur1814
    Jan 13, 2011
    1,898
    92
    Thanks ACIWD
    Will try that tonight
  8. skellyman99
    skellyman99 Pen Pal - Newbie
    Oct 27, 2011
  9. Wiz33
    Wiz33 Scribbler - Standard Member
    Mar 7, 2011
    Silicon Valley
  10. Senior Geek
    Senior Geek Computer Graphics Nut
    Nov 17, 2011
    Bellefontaine, Ohio
    I've been experiencing the flashing screen problem for some time and have been watching the posts on this forum for a solution. I installed Windows 8 on my Iconia (which I LOVE), so I couldn't send it back to Acer. I probably voided the warranty, but it's worth it. Anyway I found the solution right here on a post and it works!!! Just follow these YouTube instructions to download and install the latest Touch Screen Firmware Update from Acer:
    YouTube - ‪Random Click in lower right corner of the screen on the Iconia Tab W500.f4v‬‏
    My Iconia is back to stable operation now and I'm delighted. I do notice that the touch screen sensitivity is slightly less now and I'm guessing that's what Acer did to fix the problem. Before the update, I could just lightly tap the screen or even just pass my finger or stylus close by to get a response. Now, I need to touch it a bit more firmly, though not much, to get it to respond. No more flashing to the desktop and back. I love my Acer Iconia W500 and Windows 8. So happy that I don't have to send it away for repair or remove the Windows 8 preview version.
    Best of Luck to all of you out there with the same problem that so many of us had. I hope this works for you too!
  11. Solom01
    Solom01 Scribbler - Standard Member
    Feb 22, 2010
    141
    Actually, so long as you have access to a USB dvd disc drive it's no problem returning it to the original configuration (or to whatever you had set up in Windows 7 if you made an image with the included back up program). It's quite easy to do if you follow the instructions on this thread. I tried Windows 8 twice, and though the responsiveness was nice I wasn't a big fan of the Metro Interface and some of the other issues with the trial program (couldn't figure out how to increase the size of menus and buttons, etc.) and went back to 7. 8 certainly looks promising so I'll probably buy a copy as soon as the final release version comes out.
Similar Threads: W500 Erratic
Forum Title Date
Acer (Gateway) Acer W500 Factory Reset question Feb 26, 2014
Acer (Gateway) Acer w500 bricked Dec 15, 2013
Acer (Gateway) Acer W500 Miracast drivers? Nov 21, 2013
Acer (Gateway) android on acer W500 : windroy ! Nov 10, 2013
Acer (Gateway) w500 windows 8.1 broken rotation Nov 10, 2013
