W500 and W510 Difference
Discussion in 'Acer (Gateway)' started by adz7777, Oct 24, 2012.
  1. adz7777
    adz7777 Pen Pal - Newbie
    55
    Is there a big difference between the W500 and W510 processors?
    W500 has C-50 amd 1.0GHz processor
    W510 has Z2760 Clovertrail 1.5GHz Processor
    Would you notice the difference in these processors when using the tablet?
  2. adz7777
    55
    any opinions please? :) just not sure whether to pre order the W510 until i know what kind of difference is between the processors.
  3. rjbouw
    rjbouw Pen Pal - Newbie
    Well... from a benchmark point of view, the atom in the 510 will be faster. However the graphicspart on the w500 will be faster.
    So what this translates to, not really sure.
    But i think you should also take in account the batterylife. On the w500 its not really spectacular. Mine will last for about 4/5 hours use, the w510 should do 8. Oh, and there's the sensors (or lack of) thing on the w500. And the productsupport...
    bottomline, i'd go with the w510 if i were you.
    Hope this helps...
  4. adz7777
    55
    Yes the W510 will be lighter / thinner / better battery etc , but i'm just not sure on the performance difference between the 2 tablets :)
  5. rjbouw
    Well, if you're into stats, the W500 has the AMD C-60 cpu, the W510 has the new intel Atom Z2760 (clovertrail)
    Passmark CPU
    Intel Atom Z2760 @ 1.80GHz : 679
    vs
    AMD C-60 APU : 523
    Video Passmark G3D
    Radeon HD 6290M (c-60 apu): 194
    vs
    PowerVR SGX 545 : ?
    Can't really find good data on the graphics capability of the Atom Z2760, but here's some realworld data:
    This is a screenshot from a samsung ativ (also has atom z2760):
    This is from my own W500:
    (don't mind the diskperformance of the W500, i updated to a crucial m4 120 ssd)
    Realworld performance? Don't know!
    Hope this helps
  6. adz7777
    55
    That helps alot , thankyou!
    Theres not much difference at all!
  7. rjbouw
    No, not really, maybe it will be noticeble with some gameplay.
    Also, windows 8 makes good use of graphics hardware acceleration, so maybe the W500 wins here.
    Overall, it probably won't be much difference
Similar Threads - W500 W510 Difference
  1. cheuk4
    300
