Vivotab wifi issues
Discussion in 'Asus' started by lordbaal, Jun 8, 2014.
  1. lordbaal
    lordbaal Pen Pal - Newbie
    I have an Asus Vivotab RT. I'm starting to have wifi issues, where it just disconnects for no reason. But it shows that it's connected.
    So I would turn the wifi off, and then back on.
    I spoke to Asus, they said I would have to send it in to be repaired.
    It would be around $200 to get fixed they said.
    It's only a driver issue, it does not need to be repaired.
    Does anyone knows what I can do to keep it from disconnecting? Or where I can download a driver from?
    Their support sucks. Something that should take 2 minutes to get an answer, that take like a half hour.
  2. wshwe
    wshwe Pen Pal - Newbie
    My understanding is that you can't install downloaded drivers in Win RT. Using Windows Update is your only option. If that doesn't work you're out of luck. RT is locked down unlike Win 8.
