Vivotab Note 8 Wifi Connection
Discussion in 'Asus' started by mgerbasio, Apr 27, 2014.
  1. mgerbasio
    334
    114
    Hi,
    Anyone having problems connecting to wifi? For some reason wifi will not connect when I power up (standby or cold boot). I tried disconnecting, airplane mode, turn wifi off then on and power shutdown. The only thing that seems to work is to forget the network, then re-enter my password.
  2. mgerbasio
    334
    114
    Well now I can't seem to connect no matter what I try. I even tried powering down the router and connecting to a different hotspot. If I try to connect using the button on my router so I don't need to enter my key, I get "Windows can't get settings automatically. Enter the security key instead" on the AVTN8.
  3. BobWerk
    BobWerk Pen Pal - Newbie
    48
    You can try running the Windows troubleshooter for your WLAN adapter and reinstalling the WiFi drivers.
  4. thierryb
    1,375
    284
    You can also deactivate the bluetooth compatibility in the wifi driver in the device manager.
  5. mgerbasio
    334
    114
    I rolled back the wifi driver and it connected. Then it updated and installed the latest driver, same as the one that was loaded before the roll back, and it is still working.
    I'll try the bluetooth compatibility change if it happens again. Thanks.
