VivoTab Note 8 - USB stick or hard drive does not show up in Explorer
Discussion in 'Asus' started by chp, Apr 12, 2016.
  1. chp
    chp Pen Pal - Newbie
    If I plug a USB stick or Hard drive or similar into USB port via the standard cable that came with the device a sound plays and sometimes a driver installation runs but the device doesn't show up in explorer. I am expecting a usb stick would be mapped an allocated a drive letter the same as plugging into a laptop etc. What am I missing??
  2. Yoyo
    Yoyo Scribbler - Standard Member
    Both of my VT-8's do this randomly, and have since new. My workaround is re-inserting the USB device until it is eventually recognized.
    If someone has a better solution or even explanation for the problem, please post.
  3. thierryb
    1,394
    313
    No standard cable came with the device to connect a usb stick.
    You need to have a usb otg cable. Perhaps your cable is, or not.
    Try first with a usb stick, because often hard drive needs more power.
    You also should have a nearly broken usb connector on your AVN8.
    Does when charging, the light stay orange on your on off button?
