Vivotab Note 8 Updates and Drivers installation - safe order/sequence
Discussion in 'Asus' started by riukas, Apr 22, 2015.
  1. riukas
    riukas Pen Pal - Newbie
    What is the safe sequence of installing windows updates and drivers on AVTN8? I also mean to have stable tablet, not necessarily with "all the newest drivers" (because I read somewhere on this forum too I think that newest drivers/updates screw AVTN8s up).
    Or should I just now simply:
    1. Install all windows updates in any order, and then
    2. Install all official drivers in any order, and then install the latest wacom feel driver (7.2.1-24 at the moment)? (links are mentioned here)
    Thanks.
  2. riukas
    This also might be useful for other people setting up their AVTN8s.
    I've just contacted Asus support via chat (a person named Tevino D. has talked with me):
    Asus: There isnt a specific order as this will not affect the device negatively in any manner the drivers are downloaded.
    Me: And does it matter if Windows update goes first, or Asus drivers go first? Or it doesn't matter? Because there will surely be drivers with conflicting versions/dates from Microsoft and Asus. Which order do you recommend?
    Asus: No thats doesnt matter as there isnt any consequence to this.
    Me: So when versions/dates will be different from Asus and Microsoft, should I just choose the newer version? Or should I choose Asus version for a driver even if it is older than currently installed Microsoft version of driver?
    Asus: As mentioned there isnt a consequence to running either of the drivers or updates first.
    So this is just based on the users opinion.
    Me: What about "Wacom Feel Driver" from Wacom website? Should it be installed at the end? Should the newest version of this driver be used? (currently it is v. 7.2.1-24 on Wacom website)
    Asus: The newer version should be installed last.
    Me: Do you mean newest* (7.2.1-24) version?
    Asus: The newest version is the one I am referring to.
    (So, Tevino probably meant that currently newest 7.2.1-24 version from Wacom website should be installed at the end..)
    Note: I see that currently Asus drivers page shows Wacom Digitizer Driver version "V720-9".
    BTW, for comparison and probably as a useful guideline, here is Motion Computing support reply to the same question about J3500 tablet I have asked 2-3 years ago (it was mostly about Windows 7, and only partly about Windows 8):
    There is no order in which you must install drivers, but I recommend that you install them in the following order:
      • SATA storage driver
      • audio driver
      • button driver
      • graphics driver
      • touch drivers, if you have a touch screen
      • network card driver
      • wifi driver
      • Bluetooth
      • WWAN driver
      • Connection Manager
      • QuickNav
      • Smart Card reader, if present
      • fingerprint reader
      • virtual business card, AMT, TPM, if you use those features
      • Dashboard
    I would install all the Motion drivers, and install them first, before running MS Update.
    If you suspect that a driver is causing problems, yes, please uninstall it and then re-install it.
    If you have some AVTN8-specific practical recommendations about this process (see OP), please still share them, especially if you have used AVTN8(s) for a while.
  3. riukas
    Also, I have just checked the "Support for M80TA" downloads list on Asus website again, and I see there are some "utilities" (ASUS Live Update Utility, ASUS ACReminder, etc.), ATKACPI "driver and hotkey-related utilities", "applications" (as in "Broadcom Wireless Lan Driver and Application") and such. Really confusing - are all these required to be installed for tablet functionality or are they even useful? Are they (or at least some of them) just a "bloatware"?
    What have you installed of these, practically?
